#1 Окт. 19, 2014 20:52:36
Новый проект от Thundertiger
Frame type: Quad-Copter
Diagonal Distance: 450mm
Propeller Size: 12“x3.8”
Battery: 22.2V - 6000 mAh
Max Payload: 1.5kg
Max Take-off Weight: 3kg
Max Flight Time: 25minutes
2.4GHz Remote Control Distance(open area): 1000m
Diagonal Distance: 650mm
Frame Weight: 2.47kg (motor, esc, prop. Inc’d)
Motor Stator Size: 41x14mm
Motor KV: 340rpm/V
ESC current: 30A
ESC voltage: 6S Lipo(22.2V)
Propeller Size: 14“x4.7”
Takeoff Weight: 3.2Kg(6S/6000mAh)
Max Hover Time(est.): 18mins(6000mAh)
#t=28
Отредактировано Rait (Окт. 19, 2014 20:55:38)
