#1 Март 7, 2013 17:49:05
MENTOR - САМОЛЁТ ДЛЯ НАЧИНАЮЩИХ
Очень хороший самолёт для начинающих-MENTOR.Советую брать здесь http://shop.lindinger.at/product_info.php?products_id=71878 [shop.lindinger.at] примерно 4,8 т.р.
Product description
The ELAPOR® trainer and tug - starts at the press of a button!
The perfect all-rounder
The “forty-size” trainer (for a .40 (6.5 cc) glow motor) is still the world’s most popular type of model aircraft. The MENTOR fits neatly into this class, but there is one major difference: with its modern brushless electric motor system there are no starting problems, and it is always quiet and clean! The ailerons are operated by two servos for better control precision. The robust aluminium “tail-dragger” undercarriage offers generous ground clearance, making it possible to take off without difficulty even from imperfect grass runways. The steerable tailwheel ensures accurate manoeuvring ability on the ground.
MENTOR - the ideal first step in powered flying - with long flight times for effective trainer mode operations, too. Install a modern brushless motor and a high-performance LiPo battery, and the model is capable of towing gliders up to about 3 metres in span. MENTOR and CULARIS they make a fantastic team.
Kit contents:
Moulded ELAPOR® parts
strong CFRP spar
many plastic parts
small items
linkage components
steerable tailwheel unit
aluminium main undercarriage
wheels
decal sheet
comprehensive illustrated instructions
Features:
Reliable flying characteristics
Safe ground take-off, convincing climb rate and plenty of power for simple aerobatics - all with the recommended power system (Power set # 9704033).
Two-part wing with carbon spar joiner, removable for transport
Low minimum airspeed for ultra-safe landings
Removable cowl with quick-release latch for simple battery swap
Can be finished using any standard spray-can paints after prior treatment with MULTIprimer # 57834
Pre-fabricated moulded ELAPOR® parts
Комплектующие с HK https://www.hobbyking.com/hobbyking/store [hobbyking.com]
Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set 1 IN STOCK
Turnigy S3317M Servo 26g / 3.0kg / .14sec 2 IN STOCK
Hobbyking SS Series 60-70A ESC 2 IN STOCK
On Board Lipoly Low Voltage Alarm (2s~4s) 1 IN STOCK
Turnigy D3542/6 1000KV Brushless Outrunner Motor
Shipment International (Registered) Air Mail
Total $73
Credit Total
Отредактировано Vikto50 (Март 8, 2013 22:45:40)
#2 Март 7, 2013 19:21:08
И что?
#3 Март 7, 2013 19:39:55
И что?
http://rcstv.ru/forum/topic/895/?page=1#post-16127 [rcstv.ru]
#4 Март 7, 2013 19:41:36
Я так понимаю это всё?
#5 Март 7, 2013 20:16:28
Отредактировано OlegStv (Июнь 10, 2013 20:33:06)
#6 Март 7, 2013 20:26:34
Сразу видно чел знает о чем говорит, может лучше делиться опытом эксплуатации и комплектации?
Толку по моему гораздо больше.
#7 Март 7, 2013 20:28:13
Извиняюсь ,перевод прошел в автомате.Переделал на оригинал.
#8 Март 7, 2013 20:40:02
Вить, ты когда пишешь не спеши! Продумай всё до мелочей. Что ты хочешь донести до читателя, а тем более до новичка. А технические данные есть в любом магазине и частенько не точные! ИМХО
#9 Март 8, 2013 08:23:21
Согласен не спешите если мало информации поищите еще или лучше откажитесь от статьи, ради галки делать не нужно.
#10 Март 8, 2013 20:21:36
кто такая Галка?
#11 Март 8, 2013 20:38:03
Ты че галку не знаешь ?
#12 Март 8, 2013 23:02:52
Здесь ИМХО интересен лишь реальный опыт эксплуатации. А что продается по рекламе известно. Купи, сделай полетов 50 потом делись опытом, а так что толку смысла нет.
#13 Авг. 1, 2013 18:03:36
MENTOR - САМОЛЁТ ДЛЯ НАЧИНАЮЩИХ, но вот что бывает когда он в руках начинающих!
Снова в строю!
Отредактировано Pavel (Авг. 1, 2013 18:07:02)
#14 Авг. 1, 2013 19:47:30
Это кто же герой?
#15 Авг. 1, 2013 22:04:26
fatsonjr
блин а я себе только заказал думал что его сложно разбить.. а оказывается если умеючи - то бьется в хлам..
#16 Авг. 1, 2013 23:05:21
fatsonjr
Сложно разбить только шарик металлический, а так раз плюнуть любой!
#17 Авг. 1, 2013 23:14:24
сделай полетов 50 потом делись опытом, .
Если только у начинающих он доживёт до 50 полётов.Из 20 полётов разбивал 5 раз примерно так разбивал.Восстанавливать уже нет желания.
Отредактировано Vikto50 (Авг. 2, 2013 08:25:29)
#18 Авг. 2, 2013 06:56:06
.Востанавливать уже нет желания.
Давай из него донора сделаем пущай ещё послужит!
Отредактировано Pavel (Авг. 2, 2013 06:56:45)
#19 Авг. 2, 2013 15:56:17
Какой донор ,один хвост нормальный.
#20 Авг. 2, 2013 17:05:26
Мы и его приобщим к полетам!
